Laptop Celeron M - upgrade Aadvice please
25 Mar 2006
Thornbury
i have been given a cheap laptop which has a 1.3 celeron m cpu, i want to know what is the biggest cpu i can instal and can i fit a pentium M or does it have to be celeron M ? I intend to upgrade the ram too.
Laptop Spec
you most likely can't upgrade it
however you might be able to upgrade it if you could buy better cpu versions of it, if there are versions of it with better cpu's then you should be able to choose from any of those cpu's to upgrade with
thats a bit confusing are you trying to say i should buy a laptop with a more powerful cpu? i would have thought you could swap the cpu just like you can for a pc mobo.
it doesn't work like that, laptop cpu's aren't meant to be switched out so they just program the BIOS for a limited number of CPU's
so you have a laptop with a 1.3GHz Celeron M in it, if there is the same model laptop but with a 1.5GHz Celeron M in it then it is likely you can upgrade your laptop using a 1.5GHz Celeron M
ok thanks for explainging that i understand now, ill have a look and see what was available with that model cheers
well after much reading on wiki i took the plunge and bought a INTEL PENTIUM M 1.7Ghz CPU 400MHz SL6N5 off the auction site for £6 delivered, its the banius model with 400 fsb so im hoping it will be fine.
