Help with cable management in North East England area. Will pay for help.. :S
it is pretty easy once you get the hang of it. You could use cable ties in certain places
I went from this:
to this:
well that was a mistake. Not opening that thing for a while. While I think this case is nice looking, very specious, the room it allows for wires to pass through the back is ridiculously small. It literally allows like half a cm gap otherwise you can't close the case. Whether it's my PSU wires or the case, I dunno. But it's not managable!
BoroRob Uk if your still looking for help i am in ts1 central middlesbrough, be happy to try and help you out if you want to bring the rig down (i dont drive) and i have most of the bits n bobs a cable tidy would need here - save your £50 notes and send message via trust if your still "tied up" :D
TS1 brings back memories, place is a dump now though :D
rob u should take tony up on his offer and if im around ill pop round and help too, he is a genuinly nice man,, but wear shorts and tshirt cos its bloody roasting with all them gpu's he has running seti
If you're still after help Rob, I can help you out. I'm in sunderland by the way. I've built 100's of computers with the emphasis on cable presentation :)
rick [at] r b customs . co . u k
Cheers Cupra....temps are much improved shifted the contents of one of the 800d cases into a hafx ....do the other next week :)
My cable tidying is getting better....partly due to the choice of case :D
