Burning a password protected film
6 Sep 2008
Near Hull
Hi,
Would i be able to burn a film if it is password protected?
the license says protected content and i have the password for it, is it possible to burn to dvd/vcd and play it on a dvd player? or maybe convert it and remove the protection?
It's not copy protected/copyright.
edit: you open the film in windows media player and the enter username and password to play it. would it actually burn and work in a dvd player?
more detail needed - what is the file extension? where is the file from? what type of licensing system does it use?
It's a WMP file of a dalby forest video from a video camera, but i was sent it by a friend with the password and username.
it plays on the computer but i need to take it away from the computer on disk and play it at another friends house.
not sure on the license, just says protected content and when you play it a username and password box comes up in windows media player.
Hi,
The liecence says protected content.... and you have a password for it??? Screenshots of the file / password screen....would be a start....
A WMP file?? You mean WMV?
Can you ask your "friend" how he protected it in the first place?
When you say "the license says protected content" what exactly do you mean?
Generally the whole point of DRM protected content is to prevent burning to DVD, as DVD would then be unprotected. You'll need something that can remove the DRM from WMV files. Of course, such a program would be illegal in the UK under the Copyright and Related Rights Regulations 2003 (The UK implementation of the European Copyright Directive) so you might not find one on here. :)
