Vauxhall - Lifetime Warranty
Well so far, every advert VX have used have been abundantly clear, arguing based on what VX might put in their rear windows in the future is stretching things just a bit don't you think?
Which might be why I said 'I WONDER' and 'We'll revisit this thread..'
:rolleyes:
[TW]Fox;17110052 said:
It's very different because the lifetime warranty will last neither the lifetime of the owner nor the lifetime of the car, unless the owner changes vehicle and we consider a 'lifetime' to only be an ownership period.
It overshadows an otherwise very interesting warranty package.
I just hate the term lifetime.
If it was unlimited mileage and unlimited years, then great, call it lifetime. Anything less isn't lifetime.
Just look at it like this, there are 2 key criteria used to describe a warranty, the mileage limit and time limit,
BMW are 3 Years / Unlimited Mileage
Vx are Lifetime / 100,000 miles.
Both have a limit on one criteria, none on the other, both use the unlimited/lifetime wording to describe the lack of limit on that particular criteria, I fail to see the big differentiator in all this?
Lifetime implies no time limit, Unlimited implies no mileage limit, both seem reasonable wording for the term they are trying to describe..
I can see Fox's point to be honest.
Vauxhall have only added the word Lifetime to get headlines in the motoring press nothing more nothing less.
Surely no different to companies offering unlimited data*
*Subject to fair useage policy.
Whilst the more prestige brands rely on perceived quality and reliability, lowly Vauxhall actually back this up with what seems to be a very good offer. Interesting stuff. I hope it spreads through the industry.
Many people I have spoken too consider 100k to be the end of a cars life, they can't be convinced otherwise, many of them sell after the warranty is up 'just in case' your average punter would by one and be happy in the knowledge of a 'lifetime' warranty.
Vauxhall are being quite clever here in times of being frugal to the general public.
On a forum where most are actually interested in cars and would never be had over by the strap line 'lifetime warranty', can't it just be left to the GP?
read this it's actually limited to 60k for the first 3 years then 100k thereafter
This warranty provided by the manufacturer does not adversely affect the statutory rights of the purchaser against the seller and gives remedies in addition to those against the seller under the contract of sale. Claims by the purchaser, in particular for a defect on a vehicle, against the selling Vauxhall Distributor remain unaffected by the warranty.
General Motors UK Limited and its successors in title (hereinafter called “Vauxhall”) warrants for vehicles of their manufacture.
* 12 months, without limitation of mileage, from the date the vehicle is delivered to the original purchaser by the Authorised Distributor, as stated in the warranty booklet.
* Between 13 and 36 months with a limitation of 60,000 miles, whatever comes first.
* Beyond the limit of 60,000 miles and 36 months, whichever comes first for the lifetime of the vehicle to the first registered owner of the vehicle or until the new vehicle has been driven 100,000 miles, under the terms and conditions stated below.
* Lifetime Warranty does not apply for commercial vehicles.
1. Lifetime Warranty for the First Registered Owner
1.1. Duration of the warranty, dependence on first owner
Vauxhall undertakes that each new motor vehicle including all accessories supplied thereon by Vauxhall as original equipment will be free from defect in material or workmanship according to the state of the art under normal use and service for an unlimited time period and a maximum of 100.000 miles. The warranty is valid for the first registered owner of the vehicle who bought the vehicle at a Vauxhall Authorized Dealer.
The warranty starts with the date of delivery by the Vauxhall Dealer or date of first registration, whatever comes first.
1.2. Coverage of the lifetime warranty
The warranty applies to free of charge repair of the vehicle by a Vauxhall Authorised Repairer, i.e. Vauxhall’s obligations under this warranty being limited to repairing or replacing at its option any parts by a Vauxhall Authorized Repairer. The repair or replacement of defective parts under this undertaking will be made by the Authorised Repairer to whom the vehicle is returned, free of charge to the customer.
For the parts fitted during a repair, until expiry of the warranty mileage limitation according to Paragraph 1, the same warranty is given as for the motor vehicle, i.e. the warranty is not extended by the repair or replacement of parts even for the parts rectified or replaced. Replaced parts become the property of Vauxhall.
Warranty claims can only be made on presentation of the certificate of lifetime warranty and the Service and Warranty Booklet with the international warranty certificate completed and signed by the supplying Vauxhall Authorized Dealer. Lifetime warranty cover is also dependent upon the confirmation that the vehicle has been serviced in accordance with the manufacturers recommended servicing schedule.
Vauxhall reserves the right to appoint its own engineer to inspect the vehicle prior to any repair or replacement of
part(s) covered.
Vauxhall at its discretion may elect to agree with the owner a value for the vehicle in case the parts and labour cost of the repair exceeds the economic value of the vehicle, or in case the parts are no longer available.
Covered components of the Lifetime warranty
The Lifetime Warranty is valid only for the following components of the vehicle:
* Engine and Transmission and all attached parts, electronic parts of the powertain such as ECU.
* Powertrain: Drive Shafts, Differential gears, electronic parts of the powertrain.
* Steering: Steering gear, pump, electronic parts of the steering system.
* Brake system: ABS/ESP System including hydraulic unit, brake booster, main and wheel brake cylinders, vacuum pump, brake proportioning valve.
* Fuel System: fuel pump, injection pump, electronic parts of the fuel injection systems.
* Exhaust system: Turbo charger including actuator, electronic parts of the exhaust system, Lambda Sond.
* Cooling system: radiator, heater core, thermostat, water pump, radiator for the automatic transmission, cooling fan.
* Safety systems: Electronic control unit for airbags and for seat belt tensioners.
* Aircondition: Compressor, evaporator, condenser, fan.
* Electrical equipment: electronic control units excluding navigation, lighting and radar system, but including repair by flashing new software, generator, starter, electronic parts of the ignition system, ignition wiring, central electric units, instrument cluster unit, board computer, wiper motors, heating ventilator, horn, electronic parts of the window lifters, front/ rear window heaters (excluding breakage), electronic parts of the sunroof, the central door locking and the convertible roof.
Wiring harnesses, hoses and connectors are excluded.
Furthermore, not covered are all service maintenance repairs and wear and tear parts as mentioned in section 3 of the Vauxhall Warranty terms. Excluded is the replacement of components that have failed due to wear and tear.
The warranty does not extend to the fixing of consequential damage caused by the above mentioned covered components.
1.3. Customer duties to retain warranty
The lifetime warranty is dependent on an annual visit of the vehicle to a Vauxhall authorised repairer who will activate and validate the warranty extension for another year starting from the new activation date.
Activation and validation of the warranty is required every 12 months. This can only be carried out by a Vauxhall authorised repairer.
The activation and validation can be performed up to 14 days after the expiry date of the preceding certificates expiry date.
Annual activation and validation of the lifetime warranty cover is also dependent upon the confirmation that the vehicle has been serviced in accordance with the manufacturers recommended servicing schedule.
Vauxhall may request details of this service history at any time during the warranty period.
1.4. Data protection
The activation and validation of the lifetime warranty requires Vauxhall to maintain personal data of the owner.
Vauxhall will only use this information for the administration of the warranty and for customer satisfaction surveys relating to the vehicle.
all text taken from http://www.vauxhall.co.uk/owners_services/warranty_assistance/vauxhall_lifetime_warranty.html
(MY TWO PENCE)
So to me that says keep it serviced then pay some jock X amount of money to re-issue the warranty for another year as there is no way in hell they will take up staff time to do that free of charge vauxhall are ***** when it comes to that.
to be fair the vectra taxi i've got only showed its first problems at 130k miles and need an alternator, if their looked after driven sensibly and regularly maintained modern cars tend not to go wrong very often
Haha, classic, so if the engine explodes at 2 years and 70,000 miles, not covered. But if it explodes at 4 years and 90,000 miles, its covered?
