Hi all
Due to purchasing parts for new PC soon but thought I would use your greater expertise and knowledge to check the spec list.
The PC will be used for a little gaming (live for speed, richard burns rally - nothing too extreme) Photoshop and 3d Modelling. Things like keyboard, mouse, monitor are already decided on. I also already have a Element V case.
The Spec:
Gigabyte GA-MA790X-UD3P AMD 790X
AMD Phenom II X6 Six Core 1090T Black Edition
Corsair H50-1 CPU Cooler
Akasa PowerMax 850W
OCZ Gold 8GB (4x2GB) DDR3
XFX ATI Radeon HD 5870 1024MB
Crucial SSD C300 64GB
Samsung 1TB SATA HDD
Thank you in advance for any advice.
Greboth.
Edit: I am aiming for a budget of about £1100 or so for these part though might be able tp push upto £1200 if something special.
Edit 2: Updated spec
Gigabyte GA-890GPA-UD3H AMD 890GX
Corsair H70 CPU Cooler
Corsair AX850 850W Power Supply
Which pushes my budget to £1185, anything else in need of a change?
The Spec:
Akasa PowerMax 850W
Greboth.
I will keep an eye on though when I do order if anything better is on offer.
