Kit car / Track day car
15 Jul 2008
Hi all
I have been tracking my Audi TT and realised she isnt really a track car and I dont want to break her. So......
I want a track car that is road legal. Would you go buy an evo or would you buy a kit and make it or......
Any advice would be great. Im a motorcycle engineer so building and tools wont be a problem.
No Budget in mind, bar im not loaded. So 6k-10k. But if your building one then you spend a bit here and a bit there and takes time so more money avalible.
Im more after an idea if anyone has built themselves and any advice or is it not worth the hassel and just buy a car?
Something non turbocharged imho, find yourself a nice 318iS spend some money on suspension upgrade then have fun learning how to get the most out of the car :)
id start off with something old,small and cheap
something like a rover 100 series metro and chuck a 2.0 16v engine in it with only a couple of seats.
Old Golf GTi
I had a sierra cosworth which was great fun on the track after it had had a bit of money spent on it.
things like these will not cost the earth to fix when you do brake them which you will.
If you go for a rear wheel drive car and are not used to one do track days were you have a lot of run-off to get used to steering with the arse end if you have to.
Something like a Nissan 200SX is good for this.
something too heavy with an underpowered engine will feel slow.
Something like a 106, 205 or 306 GTI/Rallye would be ideal at the bottom end of your budget.
Isn't likely to cost you as much as some of the other suggestions to run so you can do more trackdays = more smiles!
Depends exactly what you want to drive. At that price point you have loads of options.
two seater track weapon (kit car)
two seater sports car (that sort of money could get a properly sorted mx-5 with FI)
hot hatch (LOADS of things, one that hasn't been mentioned yet is a Renault Clio)
RWD Coupe (BMW E30/E36)
4wd jap turbo-nutter I wouldn't go for a 4wd jap car like an evo if it were me because they wouldn't be as much fun as any of the others imo.
I would say a big part of the decision as to wether to go kit car or not is whether you would enjoy the build. If you fancy it, that should influence the decision. I am planning a kit car build more because I like making things rather than performance.
