A bit of background:
I currently have a Samsung NC10, and while it is still going strong, there are signs of wear and tear and it could be a bit faster. Amazing machine though, nearly 2 years old!
As I'm off to university in September, I'm currently looking for a new laptop. However, I want quite a good one, that won't slow down and should be able to handle multitasking. It won't be running anything particularly demanding, but I may put some games on it, and I will be doing word processing, powerpoints and the like. Ideally it should be able to play HD video too, as that is something my NC10 is not capable of doing.
So, with a budget around £600-700, I've only taken a look at two real candidates so far:
- Standard Macbook 13.3" - bit over budget, but meh...
- Sony Vaio 13.3"
- Sony Vaio 15.4"
I'm really keen on the Vaio laptops, they look smart and the specs are good. However, the 13" models seem to be more expensive, and the 15.4" cites a 3.5hr battery which is a bit unacceptable. I'd prefer 5hr+. I like the i3/i5 though...
Macbooks are nice, but a bit expensive and my budget limits me to the entry level whitebook, which I don't know an awful lot about.
I'm looking for:
13.3" screen, maybe 15" if battery life isn't sacrified
5 hours+ battery with normal web browsing, nothing intensive
Dedicated graphics so I can play some games and watch high-def videos
Nice design with abundance of outputs/inputs
Good screen
If you could make any suggestions, I'd be grateful to hear them. I realise I don't need to spend that much, but I'd like to splash out and get something nice. Not in a hurry either!
Thanks
- Sony Vaio 13.3"
- Sony Vaio 15.4"
I'm looking for:
Good screen
Thanks
