Hi there
Right as usual guys, two pretty incredible deals here, so check them out:-
Acer E-Machine E520 15.4" TFT, Intel Celeron 585, 2GB RAM, 250GB HDD - Windows Vista - Open Box @ £234.99 inc VAT
The brand new eMachine E520 is a brilliant offering at a fantastic price and has just landed in stock. This great laptop is designed to be robust offering great quality construction that will withstand a busy lifestyle. Ideal for home, education and business use this laptop suits all. An incredible buy at this pricing level.
It's the ideal buy for surfing the internet and using simple applications such as word and excel. The huge 250GB hard drive offers loads of space to store your favourite movies and media content, whilst 2GB RAM will ensure everything runs smoothly.
Built in wireless means you can access an increasing number of hotspots and have access to all of the info you need via the internet.
Features
- Screen size - 15.4 inch TFT (1280x800 Resolution)
- Processor - Intel Celeron 585 2.16GHz
- RAM - 2 GB
- Hard Drive - 250 GB
- Optical Drive - DVD-RW Super Multi
- Graphics - Mobile Intel® GL40
- Webcam - Integrated
- Operating System - Microsoft Windows Vista Home Basic
- Microsoft Works 9.0 (Pre-installed)
- Microsoft Office (Trial Pre-installed)
- Norton 360 (Trial Pre-installed)
- Warranty - 3 months warranty
Was [£347.99] Inc. VAT
Only £234.99 inc VAT.
ORDER NOW
MSI GeForce GTX 460 Cyclone 1024MB GDDR5 PCI-Express Graphics Card @ £187.99 inc VAT
- Cyclone Thermal Design with 9cm PWM Fan for 40% more airflow.
- Military Class Components such as Hi-C Cap provides more precise GPU voltage.
- MSI Afterburner overclocking utility Support Over Voltage function of GPU
co-development by MSI and Rivatuner, MSI releases the ultimate graphics card utility “Afterburner”. This utility enables all MSI graphics cards users to boost performance and to monitor all kinds of critical information in real-time. Afterburner is a completely free utility which is compatible with almost all MSI graphics cards. MSI Graphics Card products utilities high quality solid capacitor. For the gamers and high-end users, this feature not only means that product has better quality components within, but also provide much stronger support while users want to engage in hard-core tuning.
Features
- Core Speed: 725MHz
- Memory Speed: 1024MB GDDR5 3600MHz
- Shader Speed: 1450MHz
- 9cm PWM Fan for 40% more airflow.
- Nickel-plated copper base for better dissipation.
- Rounded design to prevent keeping dust.
- 15.7% quieter than reference design.
- Hi-C Cap provides more precise GPU voltage.
- SSC (Solid State Chock) has No Buzz noise and higher current for better overclocking ability.
- All Solid CAP for longer lifespan.
- Support Over Voltage function of GPU
- Support advanced fan speed control.
- Support burn-in stability test.
PhysX & 3DVision Surround technology
- Support PhysX technology effects for realist physics effect.
- Support 3DVision Surround technology to provide 3 monitor output simultaneously and real 3D image experience. (NVIDIA 3D Vision Surround requires NVIDIA release 256 driver, two or more graphics cards in NVIDIA SLI configuration, 3D Vision glasses, and 3D Vision-Ready displays.)
Afterburner Voltage Overclocking
PureVideo HD for Blu-ray™
Blu-ray and HD DVD movies are bringing a new level of movie-viewing experience; with high-definition image quality far surpassing standard-definition DVDs. NVIDIA PureVideo™ HD2 technology provides unsurpassed Blu-ray and HD DVD movie picture quality.
2-way SLI Ready
Delivers up to 2x the performance of a single GPU configuration for unequaled gaming experiences by allowing two cards to run in parallel. The must-have feature for performance PCI Express graphics, SLI technology dramatically scales performance on today's hottest games
Was [£199.99] Inc. VAT
Only £187.99 inc VAT.
ORDER NOW
Features
- RAM - 2 GB
ORDER NOW
Features
2-way SLI Ready
ORDER NOW
