1st Play With A 95 Watt 1055T
18 Oct 2002
Chesterfield
1st settings ive tried, not bad for a £146 cpu.
Do 20 loops of LinX @ problem size 20,000.
Impressive if it manages that :)
Very nice. A hex-core within that thermal envelope is impressive, and looks to be a good clocker too.
prime test is better tbh.
Not IMHO, i've had prime run for 8hr's solid and LinX/IBT fail in 5mins.
LinX/IBT also heats your CPU up more than Prime.
I usually do 20 loops of LinX/IBT @ 2048MB (or problem size 20,000), if it passes that (takes about an hour) I give it the 8hr Prime Blend treatment.
IBT maximum is mainly to stress the IMC imo, due to higher RAM usage, I.E, higher strain on IMC.
At 4129MHZ is nothing on a benchmark, I've done a 3DMark06 at 4172MHZ, and that 4172MHZ was stable for gaming XD.
Hell, even lasted Prime 95 till it throttled with temperatures, which is easy to resolve.
well for me it's the other way round.
i've had LinX/IBT pass 35 loops @ ~3100MB but Prime on Blend fails after ~2 hours.
So the conclusion is, best to run both :D
But as LinX is the faster test, I say do that first to give an idea of if you are in the ball park for stability ;)
Also LinX gives a good indication if your CPU is throttling (as the GFlops will drop), whereas Prime will give no indication and just plod on regardless.
not totally because if background tasks are doing something when linx/ibt are running, the GFlops will drop also.
Today I got my thermalright ultra 120 and will start the comparison soon with the 125w version.
I was getting 3400 at 1.28v with poor cooling and airflow, hitting 61C so aborted testing, at 1.18v one core dropped at that OC.
I am using 1.65v on my OCZ gold to get 1600MHz any opinions.
OP, nice results :)
Yeah but you don't run other crap while stress testing, if you are also testing for throttling.
Also if its just normal basic background stuff it won't fluctuate much, throttling you lose a good 5+ GFlops.
