Two points here, the first being that just because Flash is available it doesn't mean anyone has to install it, thus it existing for the iPad isn't really a bad thing. Secondly, you can set Flash to only enable Flash elements on demand. That means every Flash element on the page is disabled until you tap it (to instruct Flash to render that object). No annoying adverts, you only get the video/game/whatever that you wanted.
It should also be noted that if HTML5 does replace Flash it'll mean HTML5 ads replace Flash ads. I'm not so sure that's a good thing. Lower resources? Maybe. However it won't be so easy to turn them off. You can choose not to install Flash. You can choose to toggle Flash. The only weapon against HTML5 is going to be 3rd-party browser plug-ins, and they ain't gonna happen on iOS without a Jailbreak.
I'd be interested to see someone replicate this test;
http://vimeo.com/10553088
It's from a while back and it was done by an Adobe employee so it's maybe not 100% legit but it'd be cool if some people packing Froyo (or iPads running Frash) could test it out.
A voice of reason...
I've had an iPhone for 2.5 years now and not once have I gone 'FFS Apple, give me flash'.
Plenty of major sites have switched to HTML5 and if HTML5 wasn't taking over, content shouldn't be locked inside Flash files for accessibility reasons and to make the content easy to index and search. Sure offer Flash, but make sure the content is accessible to people who choose not to use it or can't use it for any reason.
As said in the thread already, if you really want Flash you can always jailbreak it.
Which major sites have gone from Flash to HTML5?
This isn't about me j/b my iPad to get Flash working. This is about flash not being on iDevice's.
EDIT: Flash cant be dead if Google and Adobe are partnering and the rumours suggest it will be part of the so called Google OS.
The only real reason Mr Job's will not allow Flash on his iDevice's is not because its "evil", but rather his iDevice's are under equipped to cope with it. They shoddy excuse that it drains the battery was lame. You don't need to do much for the battery on iDevice's to drain to be honest.
Majority of YouTube is Flash
Lol. Read post above yoursBought the iPad yet?
