Which monitor for gaming 21-23"?
26 May 2004
Dublin
Hi folks,
I'm looking to replace my old 19" samsung with something a little bit bigger.
My graphics card is ATI Radeon 5870 and I'm using 1440x900 resolution at the moment.
I was thinking of getting Dell U2211 or U2311, but I'm not sure if they're suitable for gaming, the last Dell monitor I had was a really bad experience, tons of blurring in games.
Also, would my card work with the new 1980x1080 monitors, or is that rez a bit too high?
Thanks!
Asus VG236 23" if you can find it.
Asus VG236H 23" which i unboxed in a topic which should be near the top, came with 3d vision.
yes your card would work on a 1980x1080. Your card supports 5670x1080 :D or something.
Is there a non-3D version of it? I have only one good eye, so 3D is no use to me :)
Or is this more about the 120Hz refresh rate than the geek glasses?
the ones minus the 3D kit is the VG236HE
