Laptop for World Of Warcraft
20 Jul 2009
Hey guys
Going away for a while and need a laptop to play WoW on. I only have 400 pound to spend. I need to know which one of these laptops will run WoW the best. I am not looking to have everything I high, but I need something what will at least run smoothly on medium settings keeping a nice FPS even in raids.
Please tell me which one will do the trick.
Ok here is what I found, but if you can find a better one for 400 or under let me see it!
Cheers
Oops sorry.
Maybe someone can list the specs of a laptop what could run WoW nicely then?
I will just list specs of the laptops I linked actually.
Laptop 1
Screen size - 13.3 in - 1366 x 768 HD LED LCD Screen
Processor - Intel Pentium SU4100 - 1.3 GHz
RAM - 4 GB (2GB + 2GB)
Hard Drive - 320 GB 5400rpm
Operating System - Microsoft Windows 7 Home Premium (64 bit)
Optical Drive - None
Graphics - ATI Mobility Radeon HD 4330 512MB Dedicated
Webcam - Acer Crystal Eye HD Webcam
Battery Life - Up to 8 Hours
Card Reader - yes (SD™, MMC, MS, MS PRO, xD)
Warranty - 1 Year
Laptop 2
Screen size - 15.6 in
Processor - Athlon II Dual-Core - 2.1 GHz
RAM - 3 GB
Hard Drive - 320 GB
Operating System - Microsoft Windows 7 Home Premium (64-bit)
Optical Drive - DVD Rewriter
Graphics - ATI Mobility Radeon HD 4200
Webcam - Integrated
Warranty - 1 year warranty
Laptop 3
Screen size - 15.6 in - 1366 x 768
Processor - AMD Turion II mobile processor M520 - 2.3 GHz
RAM - 3 GB
Hard Drive - 320 GB
Optical Drive - DVD±RW (±R DL) / DVD-RAM
Graphics - ATI Radeon HD 4200
Webcam - Integrated
Might wanna look out for a 9500M or so just to be safe but usually raids are more about the CPU, provided you run the game on low settings!
Yes, 'Intel Graphics' usually means onboard graphics, which can probably handle word and a little bit of flash before struggling
I am thinking number 3 is the best option?
I take it that would run WoW on medium smooth nicely?
Sorry just double checking as don't wanna get it and be disappointed.
how much money are these laptops? , bottom one has the fastest cpu but its still an old cpu designed to compete with intels core2duo chips
They are 350 to 400 pound.
But I decided to get this for 514 pound.
Processor - Intel Core 2 Duo T6600 - 2.2 GHz
RAM - 4 GB
Hard Drive - 320 GB
Operating System - Microsoft Windows 7 Home Premium 64 bit
Graphics - NVIDIA GeForce GT 240M
Webcam - Integrated
Oops sorry.
Laptop 2
Processor - Athlon II Dual-Core - 2.1 GHz **Higher Clocked Version of 2.5GHZ**
RAM - 3 GB **Came With 4GB not 3GB**
Hard Drive - 320 GB
Operating System - Microsoft Windows 7 Home Premium (64-bit) **Came With Ultimate 64 Bit**
Graphics - ATI Mobility Radeon HD 4200 512MB **Came with 1GB, States in GPU-Z**
Webcam - Integrated
I have the laptop above and i bought it in germany at a computer fair, came with a few extras that ive highlighted in red and i do play WoW on it, 25 man raids and all, i have every setting at maximum apart from shadows which i have turned off. **all the way down** and ive seen FPS as high as 200 in certain areas, alone in dungeons etc... normal FPS is about 30FPS, Hope this helps :)
