Ok gents I'm usually pretty up to date with GPUs but I was interested to see what other peoples' opinions on this subject are.
I'm looking to try 3D vision so I'll need to ditch the 5850 and get myself a green card. The two options in the title are what I came up with, though any other suggestions are welcome so long as they come in under £300. I was also considering 200 series cards but the drop from dx11 to 10 (even though it means 0 in games at the moment), lack of warranty second hand and silly costs new put me off somewhat.
Now the way I see it:
Cost: 470 is £225 ish vs 460 SLI is £290ish
Power usage: Not 100% but single card should be less.
SLI: I've only briefly used it with some 8800gt's and I'm not a fan of xfire. Should I be worried? Scaling of the 460s seems very good though.
Speed: 460 SLI is considerably faster than a 470.
Noise: 460 SLI is quieter according to reviews (pinch of salt perhaps though?).
Memory: reviews seem to find that the 768mb is enough for my res (1920x1080) but I honestly don't know if this is the case as I'm sure I read somewhere that Crysis very high at only 1680x1050 uses 800mb+.
Now I don't want this to turn into a red vs green thread. I've had two 5850s which I've been happy with but I want to try something new.
What would you guys do in my situation? Try to keep in mind that a 480 and 460 1gb SLI are both over budget.
