Hi
Can I connect a second CPU PWM fan up to the PWR_FAN connector and still have it controlled by the motherboard??
I was going to buy a PWM splitter cable so could connect them both up to the CPU_FAN connector, but if I can get away with connecting it up to the PWR connector why waist money.
@ Chris and anybody else who have RAM sockets that dont work.Hi,
Is anyone having issues running all 6 slots of ram.
I have 12GB corsair dominator 2000MHz and I can only see 8GB. I have tried lowering frequency to 1333MHz but still no joy.
CPU-z can see 12GB installed but BIOS and windows wont see it
Cheers
Chris
can this motherboard take a audigy 2 with 2 geforce 280gtx,s in sli in slots 1 and 3?...
There's Sandy Bridge coming out next year for Intel that will use a new socket and Bulldozer for AMD, although I'm not sure if that will still use the AM3 socket or not. An i7 should still last you a long time though so it depends if you want to wait till the start of next year or not. It's hard to say how the new CPUs will perform over the current generation...
Do you think I should go for it? Or should I wait for the new socket?
Which one is the newer one ?Two new beta bios to play with:
Beta Bios 0878:
http://www.mediafire.com/file/850dsymmc9j7jdd/RampageIII-Extreme-ASUS-0878.rar
1. Opened Memory Timing Selections for Ultimate Tweaking
2. General Performance Enhancements for Overclocking
3. AnandTech Memory Article BIOS - Support provided by ASUS USA Tech Support Only
Beta Bios 0002:
1. Improved Overclocking
2. General Performance Enhancements including correct Temperature Monitoring
3. Support provided by ASUS USA/UK Tech Support Only
4. Newer Code than the 0009 BIOS leak
http://www.mediafire.com/file/mi95l6dc9go2w6z/RampageIII-Extreme-ASUS-0002.rar
The usual disclaimers, run at your own risk.![]()
These are coming out thick and fast, not even had a offical one from the last 3 beta's
