Hullo everyone,
So I have decided to upgrade my tired old Scythe Ninja to some lovely watercooling goodness.
My aim is to only watercool the CPU for now then add the GPU at a later date. My case is the Antec P182.
The kit I am thinking of:
1X EK-Supreme HF - Full Nickel CPU Water Block £49.98
1X Swiftech Laing D5 Vario MCP655 12V DC Pump £74.99
1X Thermochill PA140.3 140mm Triple Radiator £86.99
1X EK Multioption Reservoir X2 250 Advanced £29.99
3X Fractal Design 140mm Silent Cooling Fan £35.94
6X Bitspower 1/2" Compression Fitting - Matte Black [WAAD-222] £41.94
3X Masterkleer 7/16" Tubing - 1m £7.47
1X Alphacool Tubing Cutter (4-14mm hose) £2.94
1X innovatek Protect PRO 250ml Prevent Your Cooler System From Corrosion. £8.99
TOTAL: £339.23
So far, I have only ordered the CPU block but need advice on the rest of the components.
The questions:
1. Will I be able to mount the res + pump combo somewhere in the case?
2. Will I be better off with a bay res + pump combo?
3. The compression fittings are a bit expensive, are there any cheaper alternatives? Meaning I still want compression fittings but perhaps a cheaper brand.
4. How loud is the pump?
5. Is there any other components I need to consider?
6. Should I go for 1/2 tubing?
7. Where can I mount the rad? I do not want to modify the case too much.
8. Anything missing?
TOTAL: £339.23
The questions:
