Odd question - Titan Quest Immortal Throne
4 Dec 2002
North Lincolnshire
Just finally got round to starting a new character with the expansion pack content added into the game and for some odd reason I can't loot anything. It's basically impossible to get gear to sell or upgrades due to this rather silly situation lol.
When I load up just the normal titan quest game I can loot everything as normal, just the expansion that seems to have a problem.
Ideas?
I'm not sure what regular TQ is like but in IT there's three loot keys:
Z, X, and ALT
They highlight different rarities of loot. If they physically won't pick up then I'm not sure what would cause that :(
I had this as well. If you go in to the main menu options, on the general tab, there is an option to lock item pick ups. Uncheck this box, you should be able to pick things up then.
Hope that helps :)
Z, X, and ALT
I didn't realise there were different keys. I just used ALT - do the other keys show you things it doesn't?
From memory, I think Z shows everything, and X shows yellow or higher items plus things you'd always want such as gold.
Yeah, Z is no filter, X filters common items and ALT filters broken items.
Hope that helps :)
Odd... mine's ticked and I can still pick up loot.
Hope that helps :)
Will have a look at this later thanks
