sweeeet. £720 for pair or each?
Pair
Have to draw a line at some point !![]()
Heard they are awesome. I am thinking about getting them.
How loud do they go? Whats the bass like?
Sustained 106dB at 0.5% total harmonic distortion levels, which is bearing on being very uncomfortable if your not a good few meters away. Loud enough to make super low dBFS input levels loud! At 50% volume, they are bearing uncomfortable with any mastered material unless you are across the other end of the room, or are mixing with low signal levels.
Bass response is fab. It was one of the things i was worried about, as they used to have such a dominant high end that the bass was always the weaker of the two frequency ranges. However, they've addressed the issue nicely by increasing the power to the woofer, as well as making it larger (7") to sustain accurately down to 42hz, which is a good 5-10hz improvement from the A7's. The accuracy is amazing. If your producing anything that really needs attention to sub 40hz frequencies then your best either looking for something else, or getting a sub, as you cant drive these woofers any lower unless you want to damage them! But generally, you can be assured that everything from 42hz through 50kHz is being faithfully represented. Same goes for the BM5A/BM6A's MKII, which again are great for everything minus the real sub frequencies, which is mere sound pressure energy more than anything else (imo)
If your a dnb producer, i'd say look elsewhere, despite everything else being great about them. If you do pop, rock, acoustic, electronic i would highly recommend them. The A8X (new model) has an even larger woofer and does indeed go even lower with the same amount of accuracy, which is why all the dnb and dance producers are eying up this slightly more beefed up varient, but i find 8.5" woofers just to be far too overpowering. 7" is a lovely balance for the work i do.
Best idea would be to ring up a dealer that has them in stock and ask for some time to come in and try them out. Ask them to set them up for you (which im sure they'll be more than happy to) and take in a reference CD. You'll know within 5 minutes if they are the speakers for you.
loving those adams! wish i could afford some, but alas i can only afford the fostex pm01 mkII's i have..
might be an idea to keep the tapco's and use them for A/B mastering - then you can average the sound between the 2
MikeHunt79 said:Those ADAM monitors always have strange looking tweeters, they're ribbons aren't they? £720 does seem quite cheap though, most ADAM stuff I've seen is normally at least 1k!
I'd be tempted to check the spec sheet for HF directivity, you may find they sound better if the tweeter is at ear level so I'd be tempted to try them without the stands and see how the sound compares
sicknote said:I recently bought the A5X's and the sound quality is sublime.
