Ah yes. If you are using a cpu only loop it can be done for cheaper. I was basing on the assumption that it would be top end cpu watercooling, with the flexibility to add other components and to overclock the nuts off the cpu
Yeh it gets very expensive when doing, cpu, mobo, gpu, thats for sure, pump needs to be top notch, blocks, so all adds up thats for sure .
thats not bad £100 what have you got?
must be ok to get a i7 920 at 4.2
I currently have the following, ThermoChill PA120.2, XSPC Single 200 Bay Pump/Reservoir, EK-Supreme LT, 1/2" Barbs, 7/16" Tubing, and 2 vipers generally @ 700rpm when idle/web browsing/films/gaming. Raise that to 1100rpm when the ambient creeps up.
Rad was on offer at the time when i got all that, think about £30ish instead of £50, so would have easily been over £100 if i did'nt get it at that time lol.
4.2 is still in testing phase as i need it stable for F@H, but its prime/ibt/linx stable with temps mid 60's, just some issues now and then with folding so will take abit more tweaking for that.
I have had it to 4.6ghz with HT on but summer ambients make the temps rise to much for my liking, touching 80's, some don't mind that but i do lol, so those kinda speeds can wait for winter
Id be interested where you could get CPU watercooling dual rad for £100. For res, rad and cpu block its £130 alone from OCUK using the cheapest parts.
Thats the thing, don't allways spec up via OCuk for water stuff lol, but that being said the Rad was bought from here, when they had them on offer. Was end of last year.
