WoW is horribly optimised, so whilst you shouldn't need a great PC to run it, you actually do if you want to everything maxed. The 'new' shadows that were added are the worst culprit for performance issues. It should be okay on most systems with them toned down a lot, but if you want the shadows on full, then I don't know really what you'll need.
Anything, actually anything, used to get 60+FPS in 40 man raids with a 3.0Ghz Pentium 4, 2GB RAM and a Radeon 9800XT.
yea i was doing nax 10 with3 years ago yes. Now, no where near that.
£1500 for a PC that plays WoW...
Often you will find those joking about how wow will work on a pocket calculator have not actually played wow since about 3 years ago.
With the expansions the requirements to actually run full detail have steadily climbed. Cpu power however is the most important factor right now, and any gfx card above a 8800gt will be fine.
First of all, WoW only uses 2 cores so you don't need a quad.
Second of all, i7 is overkill for pretty much any game out there unless you're running at really high resolutions, let alone World of Warcraft.
It's not a graphic intensive game, it's a CPU and memory intensive game, so saying that so spending 400 bucks on a GTX 480 to play WoW is just plain silly.
u seem to be contradicting yourself there, saying the game is CPU intensive, then stating you dont need a good CPU![]()
Those benchmarks are running at 1900x1200.
How many people who play WoW own a 1200 monitor?
The benchmarks the OP posted are 1920 x 1200 with a 16:10 aspect ratio. But not many people own monitors that support that, at that resolution obviously a high end graphics card is going to be useful.
