Video Editing Rig for less than £650
23 Jun 2010
grangemouth, scotland
Hey,
Going to college next week so i figured i might as well start saving up for a Rig :D
The rig will be used for Video Editing using After Effects, Premier Pro, Also Photoshop, Flash, Dreamweaver, Fireworks, etc
Hopefully i will get a Blackmagic Intensity pro/Shuttle so it will be 1080i Video id be working with. Along with whatever College throws at me :L
Not bothered about Gaming, since i have PS3 and 360 for that. So Just Video Editing and General Surfing, Email, MSN etc
Max i could afford Practically is £600
Also if im going to College does that mean i can get a Student Copy of Windows 7? Within the Budget?
Any Suggestions?
Thanks
Ross
If you are in secondary school, college or uni, you should be able to get Win7 Pro 64bit for £38 here- http://www.software4students.co.uk/...fessional_64_bit_Upgrade_Edition-details.aspx ignore the upgrade its just an oem.
This should be great for editing http://www.overclockers.co.uk/showproduct.php?prodid=FS-274-OK £605 though
Im guessing your a cod player ;)
Mainly Halo 3 Actually :L Have Adobe taken onboard with ATI cards? I thought they had better support for Nvidia or something? Or is this just palava from Nvidia fanboys? (I love both lol)
EDIT: I got a Windows 7 Upgrade Edition with my laptop think its 32Bit though but would that work? Until i saved up :L being a student and Skint lol
Antec 300 - 46.99
Gigabyte GA-H55M-UD2H Intel H55 (Socket 1156) DDR3 microATX Motherboard - 66.99
Intel Core i3 530 2.93GHz (Clarkdale) (Socket LGA1156) - Retail - 82.24
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) - 86.94
MSI GeForce GTX 460 Cyclone 768MB GDDR5 PCI-Express Graphics Card - 158.61
OCZ ModXStream Pro 500w Silent SLI Certified Modular Power Supply - 56.99
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) - 48.49
Akasa AK-CCX-4002HP Venom CPU Cooler (Socket LGA775/LGA1156/LGA1366/AM2/AM3) - 37.99
Sony Optiarc DRU-870S 24x DVD±RW SATA ReWriter (Black) - Retail - 16.99
Total - 604.41
Nvidia is better with Adobe software because of driver and hardware support. If you have used that Win 7 upgrade edition thatc ame with the laptop then you wont be able to use it.
when you say rig is that too include keyboard, mouse, monitor etc ?
if its just the case and innards :
Palit GeForce GTX 460 768MB GDDR5 PCI-Express Graphics Card £149.99 (£127.65)
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail £117.49 (£99.99)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9)£86.94 (£73.99)
Asus M4A88TD-M EVO/USB3 AMD 880G (Socket AM3) DDR3 microATX Motherboard £82.99 (£70.63)
OCZ StealthXStream 2 500W Power Supply £49.98 (£42.54)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £48.49 (£41.27)
Xigmatek Asgard Midi Tower Case - Black Xigmatek Asgard Midi Tower Case - Black £26.99 (£22.97)
Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £13.99 (£11.91)
Sub Total : £490.95
Shipping : £11.75
VAT : £87.97
Total : £590.67
Product Name Qty Price Line Total
AMD Phenom II X6 Six Core 1055T 2.80GHz (Socket AM3) - Retail AMD Phenom II X6 Six Core 1055T 2.80GHz (Socket AM3) - Retail £152.74
(£129.99) £152.74
(£129.99)
G.Skill RipJaw 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit G.Skill RipJaw 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit £82.24
(£69.99) £82.24
(£69.99)
Antec Basiq Plus 550W Modular Power Supply Antec Basiq Plus 550W Modular Power Supply £52.99
(£45.10) £52.99
(£45.10)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £48.49
(£41.27) £48.49
(£41.27)
ASRock N68C-S UCC GeForce 7025 (Socket AM3/AM2+) DDR2/DDR3 microATX Motherboard ASRock N68C-S UCC GeForce 7025 (Socket AM3/AM2+) DDR2/DDR3 microATX Motherboard £29.95
(£25.49) £29.95
(£25.49)
Sony Optiarc AD-7260S 24x DVD±RW SATA ReWriter (Black) - OEM Sony Optiarc AD-7260S 24x DVD±RW SATA ReWriter (Black) - OEM £13.99
(£11.91) £13.99
(£11.91)
Sub Total : £323.75
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.00
VAT is being charged at 17.50% VAT : £58.41
Total : £392.16
And a case + GPU of your choice, as much as CUDA adds a tad to image quality, I don't think it's worth going all the way to 460 for a rig that's not gonna be used heavily for gaming.
Good thing to consider is to just use onboard GPU for 1-2days, test your software and see if you're happy with the quality/speed - if you're happy then there will be no point in spending 150 on a GPU which you won't use, if you're not happy with it then buy one, I guess 2days extra won't make much difference for you and you might save yourself a lot of money.
Might also be worth trying to grab a 2nd hand 8800GT/S/X or 9800 for around 30-40quid.
Regarding case, I wouldn't recommend antec 300 as it's terribly overpriced for what it offers and for just around 5-10quid more you can have MUCH MUCH better cases but then it's just me and I hate any case that hasn't got side mounted HDDs and is too small to fit bigger PSU or GPU or cooler.
(£129.99) £152.74
(£129.99)
(£69.99) £82.24
(£69.99)
(£45.10) £52.99
(£45.10)
(£41.27) £48.49
(£41.27)
(£25.49) £29.95
(£25.49)
(£11.91) £13.99
(£11.91)
Sub Total : £323.75
DPD Next Day Parcel
Total : £392.16
Cant argue with the Price you squeezed that into!
I had a look even at a 9800GT For £60 Which would cope with CUDA and rendering without Breaking the bank?
So then dependent on Case choice i could keep it under £500?
I had a look at the Coolermaster Storm Scout i think it was, And i quite like the look of it, and the amount of stuff it has on it!
I do like Intel for some reason as well, but this 6 core machine looks amazing!
I seen that that board also Supports DDR2 memory, Does that Mean if i eventually needed more i could get some 1066Mhz DDR2 sticks to work alongside the DDR3 Currently Listed?
For video editing make sure you get plenty of ram and a nvidia card as it helps, speeds it up a lot in CS5..
PhoenixUK spec looks good, add a nice case maybe another 4gb ram and an nvidia card, I don't think you will need a GTX460 if you wont use for gaming so get something lower end like 8800 or a GTX260 or a 460 if you want to give gaming a go on pc..
