- 12 Aug 2010
Looking for a good monitor particularly for gaming and movies, having narrowed my choice down to two monitors, as follows:
Samsung SM2233RZ 22" 120Hz 3D Widescreen LCD Monitor - Black [LS22CMFKFV/EN]- Screen Size: 22" Widescreen
- Resolution: 1680x1050
- Contrast Ratio: 20000:1
- Brightness: 300cd/m²
- Response Time: 5ms (2D) / 3ms (3D)
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x DVI-D
- VESA Compliant
- Dimensions: 516.8mm x 421.3mm x 208.7mm
- Weight: 5.5kg
- Warranty: 3 Years On-Site
http://www.overclockers.co.uk/showproduct.php?prodid=MO-120-SA&groupid=17&catid=949&subcat=
LG Flatron W2261V-PF 22" Widescreen LCD Monitor - Black [W2261V]
- Resolution: 1920x1080
- Contrast Ratio: 50000:1
- Response Time: 2ms
- Inputs: 1x Analogue & 1x DVI-D & 1x HDMI
- Dimensions: 519.0mm x 387.0mm x 193.0mm
- Weight: 4.2kg
http://www.overclockers.co.uk/showproduct.php?prodid=MO-075-LG&groupid=17&catid=949&subcat=
From a novice point of view the LG has a better resolution, thus could arguably be better for games on a good PC? The Samsung is 120hz, therefore reduces screen tearing, so smoother than the LG but a lower rez. One aspect that concerns me is that I was ready to purchase the Samsung in Jan, but didn't. I can't help but notice that the price has not remotely dropped since Jan, so eight months later and the price is the same. Does this indicate that a price drop is imminent, also every other company has had 8 months now to develop a 120 hz 22 inch, are these soon to be released.
All in all, want to try and critique both monitors as much as possible, but I'm afraid I lack the knowledge to do so efficiently. In addition, I would like to know if there are any other 22 inch monitors better than the above.
Cheers.
Steve.
PS: Price difference is £85.
- Inputs: 1x DVI-D
- VESA Compliant
- Weight: 5.5kg
- Weight: 4.2kg
Cheers.
Steve.
