I just received my Megahalems Rev. B from OcUK today but the fan clips don't seem to be correct. The ends which clip onto the fan are shaped into triangles, making a connection seemingly impossible. Do I have a bad batch or am I just being daft?
Here's a picture of my case from the new cases gallery you should be able to see the fan clips ok to give you some idea of how they should fit.
They run top to bottom.
This might help.
http://www.tweaktown.com/popImg.php?img=prolima-tech_megahalems_015.jpg
That seems okay to me mate. Any closer pics of the clips and placement to get a better general idea of the problem you have.
Opps thought that picture was your build. Could the OP post a picture of the mounting.
Ah brilliant, that helps a great deal actually!
From the looks of the clips, I assumed they were supposed to hook into the holes, but that picture shows what needs to be done very clearly.
Cheers mate, all fixed now.![]()
