Dvd drive region change issue
13 Oct 2006
Surrey
A friend of a friend is having an issue whereby she has changed region on her DVD drive in Windows 4 times and has 1 attempt left. She wants to use that 1 attempt to change back to region 2 but it wont let her, saying that she needs media from that region to do it. She's tried putting in a region 2 DVD but it still doesnt work.
Any ideas?
Not sure how to fix the setting DVD region but I guess if worst came to worst she could use software to get around DVD region (not sure what the software is called but if you search for it I am sure you will find one)
Could try and find some region free firmware for the particular drive if it's available. Would certainly be the way I would go before using software to achieve it.
Any ideas?
From the first post.
Quote:
Originally Posted by robinbredin
Better off just buying another DVD drive, OcUK are doing them for £11, that wont break the bank.
Show me where on OcUK there is an £11 laptop DVD drive?
You did read the thread, didn't you?
Where does it say laptop.
