- 16 Jun 2010
- Manchester
Oh and thanks again JeffyB
Or comp fittings, look a lot nicer than jubilees
well, yeah, i was making the point that plastic crap clips are crap![]()
I have 2 DDC 18w and they are good but I have been told that the D5 is quieter.
...and they look poo![]()
Webbo - are you controlling the pump voltage through the aquaero or just the fans in your build. Was considering adding my ddc 18w to the 10w one in my loop atm, or just swapping in the 18w one, and voltage controlling according to temps...
When there aren't any fans a ddc 10w at 12v is noticeably noisy.![]()
Agreed but there are lots of nice mod kits for them, Bitspower and EK.
Personally I'd take the D5 over 2 DDC's as the flow rate is ridiculous when on max setting and it saves complicating your loop with 2 pumps, the only thing you wont get is redudancy if your pump fails. This is why having 2 pumps is nice, if one fails at least you have one to keep your rig ticking over.
To be honest why not go all out at get 2 D5's![]()
You can mod the 10W one into an 18w no?
No, sadly not on all of them - I think the newer ones made in the past few years have a different pcb design so you can't simply solder a wire to switch up to 18w.![]()
