I wouldn't go for OCZ Gold Memory as suggested above. I believe there not reliable and prone to failure, a fact shared with many others on these forums.
That's the first time I've heard anything like that, mind elaborating?
its a common know problem, the recent batches of cheaper OCZ gold have be known to have issues.
large numbers of DOA's have been reported with them as well
OK so here are the changes:
ZOTAC GeForce GTX 470 1280MB GDDR5 PCI-Express Graphics Card £241.99
Intel Core i5 760 2.80GHz (Lynnfield) (Socket LGA1156) - Retail £159.61
G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (F3-12800CL8D-4GBRM) £90.74
Gigabyte GA-P55M-UD2 Intel P55 (Socket 1156) DDR3 microATX Motherboard £90.60
Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK) £61.77
Antec 300 Three Hundred Ultimate Gaming Case - Black £48.39
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £46.33
Titan TTC-NK85TZ/V2 Fenrir CPU Cooler (Socket 754/939/940/AM2/LGA775/LGA1156/LGA1366) £33.98
Total : £798.39
Not sure if I want to go with the OcUK Value GeForce GTX 470 or the ZOTAC one. (£12 difference though...)
And as for the case, I think Antec 300 will be good enough considering I don't really care for the looks...
@coldfused
You think G.Skill Ripjaw (F3-12800CL8D-4GBRM) would be better then?
And guys.. what about the motherboard? Is the one I picked any good?
z0lt, its not the best motherboard tbh, its one of the worst gigabyte ones tbh.
get the H55 instead, it lacks crossfire, but is better at overclocking and cheaper.
as ur goign for nvidia, the lack of crossfire doesn't really make much difference anyways.
if you want a p55 board, the asus will be better, but it costs
more
http://www.overclockers.co.uk/showproduct.php?prodid=MB-389-AS&groupid=701&catid=5&subcat=1693
