Newbie SLI question - PCIe x16 + PCIe x4
2 Mar 2009
Nottingham
Hi guys, I have an Asus P7P55D motherboard which...
Supports ATI® Quad-GPU CrossFireX™ Technology
1 x PCIe 2.0 x16 (single at x16)
1 x PCIe 2.0 x16 slots (@x4 mode, 2.5GT/s)
If I were to get myself 2 x ATI video cards, would I be wasting valuable performance by not having 2 x full PCIe x16 slots?
As in... would it just be better to get 1 x more powerful card in the first place? I am only considering this as it's a cheaper option for me personally :)
Realised I should have entitled this post CrossFireX, not SLI - ooops!
To awsner your question, if P7P55D is your mb then you can only support one card. Crossfire needs dual x8 lanes to work effectively.
I'm pretty sure the 4x speed slot has been shown to not have that much of an impact on performance.
Hmmm, am confused then :confused:
The Asus website product page for the P7P55D says...
"Quad-GPU CrossFireX Support!"
What is this then?
Thats basicly why. Your board could hold four cards and use them ( it has four x4 lanes, effective), but at 70% or less. And in dual crossfire it would still be 70% as the faster card would slow for the slower card. Which would result in less performance with two cards than one.
Wouldn't that be 70% of the 2 cards speed, so actually 140%?
Still less than you'd get with full speed sockets, but maybe a noticeable boost?
Also, you need to consider the graphic cards used. I think the fastest cards are only just maxing out the x8 speed slots. So, 2 480's would be heavily hit by using a x4 slot, but 2 460s or 5830s might not be as hard hit.
Doesn't matter, it would slow down by 30%, not more than that. It's still a pretty huge difference and I'd rather consider swapping a card over than buying another one for 4x crossfire. 8x/8x on the other hand losses only about 3% performance compared to X58 16x/16x Crossfire, which is by no means a biggie.
The specs are wrong if it's this board. As far as i know all P55 boards that have a pair of pci-e slots run the top slot at 16x with one card but if two cards are used then both slots run at 8x. The review i linked to confirms this. In which case using a pair of cards in crossfire will be fine.
You're wrong, only higher-end P55 boards do symmetrical 8x/8x Crossfire/SLI. Asus P7P55D doesn't.
Expansion Slots
1 x PCI Express 2.0 x16 slots (@x4 mode, 2.5GT/s)
2 x PCI Express 2.0 x1 (2.5GT/s)
3 x PCI
I most certainly did'nt. Did you even read it? Look here, 5th picture down and the paragraph under it. It states the following:-
"There are plenty of expansion slots available here with the P7P55D - The CPU itself provides the support for those two PCI Express 2.0 16x slots (which run in a dual 8x configuration in a multi-GPU configuration), while the P55 chipset itself gives us another two PCI Express 2.0 1x slots and three old-school PCI slots."
How can i misinterpret that?
Yeah second slot is definatly on 4x. I made this mistake when buying my new board as the description on the OC site wasnt clear. If I'd bothered to check the Asus site i would have realised. Needless to say I returned it...
It's quite a big performance hit, considering crossfire scaling is not always great anyway a further decrease would just make it a waste of time.
I remember trying 4850 CF on a 16x + 4x board and the performance was poor.
