- 10 Apr 2004
Basically I have a fully legit code for W7 x64 Pro off MSDN from my Engineering Based Uni.
Now I require this to be able to be booted natively (Bootcamp) and virtualised (VMware fusion) depending on my work/gaming needs.
Windows XP has been installed with a legit copy and a legit code and it's happy enough.
Now, I did this:
1. Installed Windows 7 x64 on a partition, activated it fine, installed some apps, everyone is happy.
2. Installed the latest VMware, installed VMWare tools.
3. Activated in VMWare tools using the same code as No. 1 (as im not going to buy another code... it's the same computer!).
4. Every time I boot into Bootcamp (IE Natively) it asks to reactivate because apparently im the victim of software piracy!!
Now, this is bloody ridiculous and is exactly the reason I really hate Windows and I would like a way to fix this problem before I give up totally because I can live without Windows 7. I can live with a less pretty XP but one that doesn't argue the toss because it's virtualised on the same computer.
Any ideas on how to fix the issue? (PS: Im NOT buying Windows 7 Retail when I have 4 free codes (2x 64, 2x32) to use)
Cheers
Now, I did this:
Cheers
