***Borderlands Midweek Madness Steam 66% off***
DRM Warning
The DLC, but not the full game, uses SecuROM with a 5 install limit. Just a heads up as I know some people won't touch it with a bargepole.
Again, the full game does not use this, just the DLC. And yes, the steam DLC still uses it.
Damit! :P could have posted sooner :P for sure going to format the pc/laptop more than 5 times in its lifetime and have to dl BL+DLC again oh well..was only £6
Nope, they are downloaded as part of the game. If you right click it when it is downloaded then "view downloadable content".
Thanks
I've bought the 3 dlc and now borderlands won't run at all. It just says can't connect to key server
from valve
We have run out of keys for the Zombie Island of Dr. Ned DLC.
As soon as we get more, you'll get them. We expect to have this resolved soon.
For now, we have removed the CD Key prompt when starting the game, so the base game and other DLCs will be available to you as normal.
http://forums.steampowered.com/forums/showthread.php?t=1341309
Word of warning to ATI users. 10.7 cats are causing a memory leak which causes stutter then crashes the game. This is well documented on both the AMD game and steam forums amongst others.
from valve
Thanks for that. if it's a common problem it should be sorted soon. I was only going to buy Dr. Ned but then just bought all 3. It's a shame they don't list sperately in my Steam list.
