- 10 Jan 2009
Just splashed out on a Gainward gtx 260 to run in SLI with my current XFX black edition - problem is that the Gainward, with has the twin rather than single fan configuration, has its SLI pins offset ~5mm along the card relative to the XFX. Annoyingly this means by rigid SLI bridge which came with my motherboard won't fit (I had a go forcing it, but there was more chance of it breaking rather than fitting). Anyone else had this problem? Anyone seen any flexible bridges available anywhere?
I gather the bridge isn't essential, so rigged it all up and booted. It posted fine but no display on the screen whatsoever. I tried attaching my monitor to the dvi ports on each card in turn without success. The Gainward card is in the place of my old card and connected with the same lead from the PSU, however there is no air exhausting out the back... The XFX card is connected to a previously unused slot and cable from the PSU and spins up fine, but still no picture on screen when connected to my monitor... Any ideas what's going on? I will try the Gainward card its own next to check that isn't dead
Any help much appreciated!
