- 3 Jul 2005
ok boring thread but im just wondering what would happen if there was water trapped in a metal ball and it was heated? would it explode because of the pressure? thanks
isnt this similar to how heat pipes work for a cpu? wouldnt the water boil forever as it couldnt evaporate?
Boiling is a form of evaporation. If the pressure was high enough, the water would just not boil.
R - Avogadro's constant
O'Rly?![]()
Gas constant.
Ricochet J,
does it all depend on the temp applied then?
The ball essentially in this scenerio is a pressure vessel.
The ideal gas equation states:
Pv = RT
Where
P - pressure
v - Volume
R - Gas constant
T - Temperature
Since this is a pressure vessel, the volume is not allowed to increase. In this case as temperature rises, pressure will also rise. This will lead to an eventual rupture in the ball.
would it still explode if a bear of weight equal to the force exerted radially by the water stood on it?
