Water pressure completely gone?
27 Dec 2006
Northampton
I live in a town house (3 floors) and the tap from the top of the house has no water coming out any more.
When I turn the tap it just makes a slight noise. Going to the ground floor, the kitchen tap works but the pressure is ever so weak. The downstaires tap also has no water coming out.
Is their a bust or how do i find out if there is somethign wrong with my system?
If you are able to put your thumb over an open tap and stop the flow, that counts as ZERO supply (So i heard when recently dealing with a water pressure issue) and that means they will react very quickly.
Sound as if the water supply has been cut off. Anyone working outside? You could also ask your neighbours.
hanks for the advise guys, spoken to neighbour and they checked. Also no water pressure.
Phoned Anglia water and they knew there was a problem. Shame its not updated in real time on their website like the Highway agency.
Best Option: Ask neighbours and if they have the same problem call your water supplier. If they don't have the same problem, still call your water supplier.
EDIT: Darn I was too slow
