Turn auto on.
so userdefined and then auto on?
Turn auto on.
Try 800MHz next. It would probably be fine unless you unlucky enough and got a crap core.All sorted now. too easy lol,
I'm upto 751/1502 with mem clocks on default. Gonnna play crysis warhead on that now !
sid
What temps are you getting ?
This 470 does seem to run cooler than others - I just put one in a machine for a friend seeing as they are cheap and his hits 80C in games even with my modified fan profile (whereas mines 71C with same settings).
I have very good airflow in this case tho which massively drops temps until you hit the cooler saturation.
EDIT: I have a coolermaster V8 on my CPU - but it has its own airflow entirely seperated from the GPU area so its probably no difference to a watercooled setup for impact on the overall temps - once my GPU stabalises in furmarks (somewhere around 80% fanspeed) no amount of turning the fan up results in any drop in temps even at 100% it still stabalises at 91C.
850 is my max stable clock with 1.087v but I usually just run with 800 24/7. With the memory I gain bugger all performance so just stuck it at a moderate 1750.
Rroff is the memory stable at 2000? I thought it was inferior to what the 480 uses.
Don't suppose you have a power plug wattage monitor jobby do ya? Just out of interest could you run any old benchmark at stock settings, voltage/clocks, then whatever you can run on stock voltage highest clocks, and both of those clocks with voltage at 1.05v, would be very interested to see if the wattage usage scales as badly as those leaks suggest(leaks of 512sp 485gtx power that is).
