- 13 Jan 2004
- Leicestershire
this thread is epic!
it's mpg for god sake.....
mine does 38mpg.
mine does 38mpg.
So your best ever mpg, which you leave us to work out? Great!
Fill up = 71.00/1.159 = 61.251 litres
61.251 litres = approx 13.47 gallons
535 miles using 12.47 gallons = just under 43 mpg
Extra Urban mpg for the 2.0 SE = 46.3 mpg
So your best ever mpg is 3.3 lower than the manufacturers guide figure.
Well done!
I work this out to 39.7MPG
Me too.
I only have a computer that I can reset manually - So I can only brim it, drive, then see how much it takes to brim again.
It is a 10 year old micra the problem isn't the 59hp, it is the 59lb/ft of torque (I am sure some lawnmowers have more!).
Taking it easy gets 43mpg but I don't do motorways often.
It really does suprise me how efficient modern engines are now.
iirc the new 1.6 Fiesta has exactly twice the hp yet the mpg is almost as good, with emissions that are lower!
.. in my 51 plate Audi A4 2.0 SE (Petrol).
535 miles on one tank (with 40 miles remaining according to the trip computer). Cost me £71.00 at £1.15.9 per litre to fill her up again.
Did take some serious restraint on the gas pedal!! Took Top Gear's advice and stayed off the gas while in gear when possible. Apparetly the car does not use any fuel when doing this. Not sure how much truth is in that but it gave me over 100 miles more than I usually get out of a tank![]()
taking your foot off the 'gas' when in gear isn't coasting.
[TW]Fox;17202131 said:Your best ever figure matches my best ever figure.
You drive a 2 litre 4 pot, I drive a 3 litre 6 pot.
This thread fails the so what test.
