- 17 Aug 2003
- Woburn Sand Dunes
Higher idle temps, power consumption in the long run? Why cause this if can be avoided?
it can be avoided and is being avoided by the people who can be bothered to spend 10 minutes installing afterburner. no its not ideal, yes ATi should sort it themselves but until they do, *We* all have working solutions.
Tbh, its boring reading post after post of bitching about clock speeds every time a driver is released.
RavenXXX2 said:Yeah well one more reason to stay with Nvidia
lol.
ATi cards have 3 basic clock profiles:
Idle - self explanatory; ~157MHz GPU, 300MHz Memory
Bluray/AVIVO - For when playing dvds, H/W accelerated videos and flash; ~400MHz Gpu, 900MHz Memory (hence the mem clock drops to 900MHz on youtube videos)
3D - Games; max clocks
It works as its supposed to, dont see what the complaint is about
if you overclock, the standard profiles dont work. That's the complaint. My 5850 is slightly overclocked - runs at 900/1100. with this clock, the ram never runs slower than 1100 and the core will clock down to 400mhz and no less. this is why i use afterburner to set a 2nd 2d profile with standard clocks - that way when in 2d mode it clocks down as it should (157/300) and when afterburner detects 3d it ramps the clocks up to my O/C settings.
it's a fix for dodgy drivers but it works so...meh
And the clocks go up to 400/900 then. I'm talking an overclocked 5850 here.
