- 30 Sep 2005
I have just installed the Corsair H70 this morning and am amazed at my load temps. Installation was a breeze and it has dropped 10c from my load temps (went from an Akasa Freedom)
The only slight problem I have is that now I am getting good temps I have decided to ramp up my overclock. Now standing at 4.01ghz with the following
Intel i7 870
Gigabyte UD2 P55
4GB Corsair DDR3 2000Mhz
Multi - 21
Bclk - 191
CPU and VTT Volts are 1.4v
PCI Locked at 100Mhz
Turbo and Volt C-State Managements are all disabled
The system boots fine but when I start encoding using x264 it crashed out after about 3 minutes. No blue screens or lockups though.
My temps were all looking great so it's not a heat issue.
any tips?
Thanks!
Intel i7 870
Gigabyte UD2 P55
Multi - 21
Bclk - 191
any tips?
Thanks!
