As it stands, I have an Antec 900 case, and its a mess. Its the original one, so no dust filters, meaning every so often I need to take the case out and blast it with an air compressor, and there's no real cable management, its not got holes for stuff to go behind the motherboard tray, and I did consider dremmeling out some, but the main PSU cables wouldn't have had enough room to fit between the tray and the case side, so that's been out of the question. Also, the fan speed controls are on tiny little wires inside the case, which is useless and means they never have their speeds changed. Them being accessible means I could lower the speeds overnight and turn them up when gaming, for example.
But its almost student loan time again, which means some money to squander on a new case which will hopefully address these niggles.
I'm not opposed to moving up to a full tower case, as it usually means more room for fans and better cooling in general. I must admit to looking at the Antec DF-85. Not the prettiest case around, but I do prefer function over aesthetics, and it seemed to have ample cooling and good cable management solutions. But I'm not too clued in with cases other than those by Antec. I'd say I can stretch to around £130, maybe a little more, but only if its really worth it.
As I said, I'm more after functionality over aesthetics, good cooling and cable management, and I'm not against a full tower case.
