Knew it was too good to be true, it runs windows fine, but as soon as it requires anything from the graphics card it just locks out then goes black.
Installed the drivers with the disc, noticed the issue. So I went to the ATi website to download the latest ones. Same again freezes when doing anything 3D. (yes the old drivers were taken off, rebooted then done the new ones)
The default games with Windows 7 such as Chess Titans work, however, even in the Catalyst Control Panel if I go to the "3D" tab, and just move it from default to high it causes a issue.
Everything is still default, no overclocking, tried the card in all 3 slots on the motherboard with the same results with each. Asus Probe II says the CPU is 42, and the mobo is 38. Catalyst reckons the GPU is also 34.
Any suggestions?
Catalyst Information:
Graphics: (All greyed out)
GPU Clock: 850mhz
Memory Clock: 1200mhz
Fan Control: 50%
Current Values:
GPU Clock: 157mhz
Memory Clock: 300mhz
Information Center:
Catalyst Version: 10.7
2D Driver Version: 9.01.01.1047
Direct 3D Version: 8.14.10.0768
OpenlGL Version: 6.14.10.10061
Catalyst CCV: 2010.0706.2128.36662
/edit: Retried the x1650, playing games fine for the last 10minutes, althought the fan does seem to be spinning faster than in the case it came from. So I am wondering if the new 5770 could be faulty, or if there are recommended bios settings to be changed to make it work with the 1366 socket boards, chip and ram :<
Any suggestions?
GPU Clock: 850mhz
Fan Control: 50%
Current Values:
GPU Clock: 157mhz
Information Center:
