- 7 Feb 2010
- Essex
My machine last worked about 8 weeks ago before a big problem knocked it for 6. Recent house move has prevented me looking into it. Today I started getting serious in my attempts to fix. Ended in frustration as I just don't know enough about wat could be wrong..
Machine
Pny GT8800 GT 512MB
Abit IP35
Vista 64
4* 1g Corsair DDR2
ANTEC case
Freezer Pro 7 cooler
This machine had been giving me randon BSODs in the past. Then suddenly I got
Award BootBlock BIOS v1.0
BIOS RomChecksum error
a few more lines
Machine wouldn't get past this point no matter what I did. Couldn't get into BIOS absolutly no way past this screen.
Machine had been OC'ed by OCUK when I bought it a couple of years ago and I think the last time I got it to boot into the BIOS I did try to switch it to the un-OC'ed profile.
Things I have done so far to try to help/fix.. (I always think you know when you have done something that has made a difference and I certainly haven't had that feeling..)
I cleared the CMOS memory using jumpers as I thought I had a corrupt BIOS.
I changed the CCMOS1 battery in case it had run down
I stripped the machine cleaning all dust from PSU & case & GPU etc.. Huge amounts dust. Used only cans of air no vacum cleaning!
I reapplied Arctic 5 to CPU & Cooler and boy did they need it!
All done wearing anti-static wrist strap & grounding etc..
I try to power up & MB gets the red light it is meant to saying power going to the board then all fans start run on full then stop for a sec (this is what they have always done..) then back on again full. There is green light on MB where there is supposed to be one. Everything looks absolutly perfect to my untrained eye. The trouble is absolutly nothing is going to the screen. The screen is on I have checked both DVI outputs etc etc.. nothing. Screen is working perfectly as picks up laptop every time.
Can anyone think of any steps I can take to try to get somewhere?
Could it be PSU failure? It looks perfect and fan is spinning and it seems like it is all working.
Same with GPU
Totally lost as to what to do next...
Any help advise greatly appreciated. This machine has never been really perfect for a while with the BSODs and I wonder if they could be a signal that something was wrong and now it is finally fried...? My changes made to the BIOS settings cause me concern.. but I can't even get the BootBlock to come up any more..
I can post pics of the inside if they would be of any use...
ta
Mal
Machine
Pny GT8800 GT 512MB
Abit IP35
Vista 64
4* 1g Corsair DDR2
ANTEC case
a few more lines
Same with GPU
ta
Mal
