Poll: ****Official Battlefield Bad Company 2 Thread*****
Which type of game play would you prefer
  • Normal Rush Mode
    Votes: 481 33.4%
  • Hardcore Rush Mode
    Votes: 222 15.4%
  • Normal Conquest
    Votes: 507 35.2%
  • Hardcore Conquest
    Votes: 229 15.9%
  • Total voters
    1,439
Why have a go at someones grammar, when you are no better at it.
Massive fail on your part.
Any way, back on topic, I notice a lot of bans today, bit of a crack down going on by the looks of it.:)
Lol, well I'm so thick I did not notice he'd made a mistake spelling British wrong must be the Americzzzzan in me.
Yep I've noticed a good few bans today hope they keep them up.
That's a spelling mistake rather than a grammatical one.
Either way, far less bad than using 'no' instead of 'know' and correcting an already correct spelling.
edit: and correcting a nonsensical word like 'smackdown' is a bit rich.
Anyone playing this right now ? I can't seem to add the OCUK server using the favourite bit in user settings, but then server appears to be offline.
I need my fix!
against vehicles yes, but does less splash damage so is less effective against infantry (still a one hit kill but you have to get it closer)
I've also noticed that the RPG7 seems less agile in the air that the CG. Maybe it's just me but the CG seems to turn slightly quicker (when firing at choppers). Hence, a CG is more likely to hit, but do slightly less damage than a RPG7.
Also, remember that tank/apc armour is thicker up front. Best spot is to get above them (on a building roof and fire down onto their top). RPG7 + Explosive MkII should kill an APC instantly if done like this (unless I was lucky and it was already damaged!). Next is from behind, side then front as a last resort.
Any rocket hit anywhere on a chopper will take it down instantly, although if they bail in time you won't get the kills.
I have the [OcUK] Tags.
I play on the {SAS} server.
Now I wanna talk! :D
What voice servers are you guys using? I've been onto the {SAS} TS3 server (or was it vent) but none of you guys seem to use it.
im fairly sure mast damage is from the back? always used to be (apart from in the vents of walkers in 2142) :D
anyone else havign problesm with sights at the moment? every so often i bring them and they bounce back into no sighted then back into sighted again then out then i have to once again try and sight up. seems to happen more if i have 3 buttons pressed down (particularly back)
any ideas?
the cg flies quicker normally but the rpg7 gets a speed boost when locked on a tracer, not sure if it's more nimble though.
although for tanks it's rear armour that's the weak spot, but apcs it's rear and top, not sure if top applies to tanks but it definitely does for apcs, if you hit the rear top with an rpg7 mk2 they are definitely bailing even if you don't kill it.
i use knubje's vent (search this thread) or defrags mumble.
ip: 195.90.99.195
port: 62705
50 Channel Mumble server, anyone welcome to use it. Please don't spam TTS or Voice Chat otherwise I'll boot you off! :)
Either is fine, however with Vent I get voice lag and people constantly playing loud music/spamming in channel (not Ocuk people, just random idiots), so I tend to use Mumble a lot these days.
