Some places in Wow run at <30 FPS on an I7 920 with an ATI 5870.
Never consider WoW as a determining factor for a hardware upgrade, the game is just poorly coded.
But that £79.99 4870 is great value, and it has sufficient cooling for that card.
Well since I want to play wow, shouldn't that be determining what card I should get.
How do I know if my mobo will run GDDR5
Sure. But it probably would be useful if you can say what spec is your system as well (CPU etc).Well since I want to play wow, shouldn't that be determining what card I should get.
