I'm not sure what's unscientific about it, other than the fact that anyone can work it out. A fuel with more energy will get you further per gallon than another fuel with less energy.
AHhahahahahaha.
It had to be you that claimed it was legit
Because theory is clear on what is possible, I mean I've experienced the results myself, but perhaps the literature they advertise is what they believe to be more consumer friendly. This isn't just T99/Momentum, but any SUL.
So you are basically saying you suspect the figures are accurate and that you can indeed get up to 25% more economy by using SUL?!
