looking to get speakers/amp for pc and tv
4 Feb 2003
telford, shropshire
hi,
the issue i have is how can i organise them to get the best sound distribution for gaming on the pc and when listening to the pc.
was thinking of a a set of wharfdale 9 speakers with a cambridge a1 amp (after checking around here for ideas).
but without moving the speakers depending on my requirements i can't see that i will get the right setup or am i missing something obvious ?
cheers.......
What do you mean by organise/distribution?, if you mean speaker placement then preferably to get the best out of bookshelf speakers they should be on stands, be a good distance apart and slightly toed-in.
yeah sorry, the placement, problem is that i can't see they can be placed to be used on the pc and tv, its a case of moving them for best placement at the pc or tv :confused:
you could just place them ontop of your pc desk if you have enough room.
i realise that, but if i do that, when i want to use them for the tv the angle they play at will be offset from where the tv is, i'm wondering if the sound will be off putting or won't i really notice ?
