- 20 Feb 2009
- Ashton-Under-Lyne
I'm currently browsing though, making decisions so that I have a rough idea on the parts I want for my build in October (ish, possibly a little later) time, but I'm unsure of which gfx card. Should I get a single 480 (I'm not sure my budget can stretch to SLI 480 unless the price drops to around 5870 territory by then), crossfire 5870, or a 5970.
I considered the crossfire 5870 for a couple of reasons:
1. I run 3 monitors (extended, not eyefinity), so the duel cards will allow my to hook them all up via DVI, rather than having to buy a DP->VGA converter, and having to use VGA for one.
2. 2 cards allways looks better in a build, especially when watercooled (as mine will most probably be)
3. from the benchmarks I have seen, it has a slight performace advantage ver the 5970, although only by a couple of fps.
Other than those points, I have nothing pushing me to any one over the other.
I run 3 monitors, a 26" centre @ 1920*1200, and 2 19" sides @ 1280*1024
