vesa mount and plasterboards walls?
23 Nov 2009
North Leicestershire
going to be picking up a vesa for my 22 inch monitor, will it hold on a plaster board wall the mount only has 2 fixing points was thinking of using mavity toggles or interset rawlplugs. But don't fancy pulling out chunks of plaster unless anyone knows a hassle free way of fixing into the blockwork
If you have blockwork behind the plasterboard then why not just drill into that and fix with red/brown plugs??
Failing that plasterboard fixings, the screw in type I mean.
Or the messy way, make hole, insert batton, fix, watch tv/use pc.
my walls are dry-lined and have blocks behind the plasterboard (1inch gap) I used 100mm frame fixings to hang my 42" lcd, they seem to work quite well....
I think the blockwork is about 100mm away as it's plaster board,void,blockwork so would need so heffing long bolts and some good look the get the screw in the rawl plug
dosen't seem like there is any studwork so think to board is bonded to the wall.
If it's a 100mm gap there will be studs, it's to deep for bonding, try drilling a lil hole and taking a peek
