OCUK EXTREME H2O GEFORCE GTX 460 1024MB GDDR5 PCI-EXPRESS GRAPHICS CARD
11 Dec 2005
Cheshire
OcUK Extreme H2O GeForce GTX 460 1024MB GDDR5 PCI-Express Graphics Card @ £264.99 inc VAT
The OcUK Extreme H2O GeForce GTX 460 is the most powerful graphics card in it's price bracket, with immense overclocking potential and cool temps it isn't hard to see why. Paired with the excellent EK GeForce GTX 460 Full cover water block the OcUK Extreme H2O GTX 460 is the gamer's choice, maximum power, cooling and silence all in one fanastic package. Shipping out with the waterblock pre-installed and tested you have peace of mind guaranteed. We also endorse a guaranteed minimum overclock of 850MHz on the core, yes 850MHz! This means you don't need to worry about receiving a card that doesn't overclock well. Enjoy speedy framerates and smooth gameplay with the OcUK Extreme H2O GTX 460.
For overclocking, OcUK recommends the MSI Afterburner Overclocking tool.
Features
- Core Clock: 675MHz (850MHz overclock capable guaranteed)
- Memory: 1024MB GDDR5
- Memory Clock: 3600MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 336
- Shader Clock: 1350MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.3a & 1x DisplayPort.
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 5 Years
- Supplied with Prince of Persia - The Forgotton Sands PC Game
- Waterblock: EK GeForce GTX 460 Full Cover - Nickel Acetal
* All graphics cards are blocked and fitted to order so please allow a lead time between 24 - 48 hours.
* Due to the nature of GFX card overclocking cards ship out at there stock speed (675MHz) but with user overclocking will reach 850MHz core minimum.
Only £264.99 inc VAT.
ORDER NOW
I mean 2x 470 or 2x 460.
EDIT: The 460 and 470 scale very very well and ive not heard of much driver issues on the nivdia side.
Is that stable with no artifacts?
Most people have found 900mhz to be the upper limit on air so this is pretty decent!
That was stable my friend or should I say is stable lolz. Very impressed the amount of difference the waterblock adds is immense!
I don't want to spam old post up, but any chance of those h20 Coolermaster Cosmos pictures? :D I'll stop bugging you if you ask me too. heh.
Do you get the stock cooler with the card? I mean, I know its a WC'd card, but still, its nice to have as a fallback option :D
Hi,
Sorry about the delay with the pictures. We havent got any pics of the Eclipse system with the cosmos case as we are OOS and the customers that bought eclipses changed the case. The ETA for the case is around october time at the minute!
Ah no worries. I've almost come to terms with the incredibly hard cable management of the case anyway :p
Really?, Ive only just got my MSI one so have just started to tinker ive just ran the same settings on my aircooled msi cyclone with the exception it was running the ram at 2205mhz totally stable without any artifacts in 3d06 temp peaked at 62C is that ok?
Just out of interest do you send the stock coolers with the cards too? I thought these were factory installed till i re read the initial post.
We keep hold of the stock coolers for RMA purposes. As if a card needs to be RMAed and the customer loses the cooler they will not be covered.
