TODAY ONLY DEALS - 25/08/2010 - XFX & Gainward!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Another two stunning deals on TODAY ONLY:-
Gainward GeForce GTX 295 1792MB GDDR3 PCI-Express Graphics Card (Dual PCB) - OEM (Grade A OEM - 3 Months Warranty) @ £205.61 inc VAT
Engineered for extreme gaming performance, the NVIDIA GeForce GTX 295 is the most powerful dual chip graphics card on the planet for gaming and beyond. Experience the hottest games such as Far Cry 2, Mirror's Edge, and Call of Duty 5: World at War at extreme HD resolutions and ultra high image quality with the power of two GeForce GTX 200 Series GPUs on a single card. And then go beyond traditional graphics with Graphics Plus and experience GPU accelerated NVIDIA PhysX gaming effects, Stereoscopic 3D gaming, video processing for transcoding HD videos in minutes to your portable video player, and lightning fast image processing using Adobe CS4.
- Core Clock: 576MHz
- Memory: 1792MB GDDR3
- Memory Clock: 1998MHz (Effective)
- Memory Interface: 896-Bit
- Processing Cores: 480
- Shader Clock: 1242MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI
- SLI Ready
- HDCP Capable
- DirectX 10 Support
- OpenGL 3.0 Support
- PhysX Enabled
- CUDA Enabled
- Excellent for FOLDING (Average 15,000 PPD)
- Warranty: 3 Months (This is a Grade A refurbished product)
Was [£234.99] Inc. VAT
Only £205.61 inc VAT.
ORDER NOW
XFX ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card ***Supplied with Stalker & Stormrise Games*** @ £193.86 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 5800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 725MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Memory Bandwidth: 128.0GB/s
- Processing Cores: 1440
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- Supplied with Stalker Call of Pripyat &Stormrise Digital Download Coupon PC Games (As of 11/08/2010)
***EXCLUSIVE Premium Priority 2 Year Warranty***
In the unlikely event of your card failing within 2 Years, OcUK will replace your card with a brand new one, pending testing within our standard RMA terms and conditions (http://www.overclockers.co.uk/support.php)
Was [£214.99] Inc. VAT
Only £193.86 inc VAT.
ORDER NOW
For that price, the 5850 is looking like a real competitor to the 460 again. Actually, it might very well just straight up beat it.
xfx 5850
I have a ati 4870 at the moment,and am wondering will i see a big difference if i buy the XFX 5850 which is on sale at today.
Also would i be able to put a third party cooler on it(i know that it would disable the gurantee)something like an Arctic Cooler?
I play at 1920x1200 res on a 26" monitor.Winxp pro.CPU [email protected]
Thanks.
Thanks.
Here's some comparison:
http://www.anandtech.com/bench/Product/176?vs=164
As for aftermarket VGA cooler, it might not fit XFX 5850 since it is most likely not with a reference PCB. I have a Akasa Vortexx NEO VGA Cooler that I wanted to fit onto my XFX9800GTX+, but XFX's custom designed PCB has some capacitors positioned in spots that's getting in the way, so I couldn't fit the cooler on it (not unless I tear the capacitors off the PCB...but pretty sure the card would be borked after that lol).
Marine-RX179
Thanks for the info,and the comparison website,it looks as if the 5850 beats the 4870 by quite a distance.
Pity about the cooler though,as i always fit a third party cooler to my v/cs,because its not a reference pcb,does that mean there are no coolers on the market to fit to it at all.?
Do you know if it is very noisy at full load.?
Thanks.
Not really, the GTX460 has also dropped in price to sub £165 territory (1GB models).
The price difference is still ~£30 (more like £40 as there is only 1HD5850 at the sub £200 price point) as it was around the GTX460 launch.
I agree though its an excellent price for such a competitive card.
Yeah you are right, it does not really beat it as such, but at least if prices moved into this territory it would regain some of its place in the market. There is a squeeze between the point of the 460 and 470 and the 5850 will definitely be a lot more attractive if it could go further down.
Then again, I have no idea about real world stats for sales, the price point might be fine even at the perceived higher end but in terms of tangible power for price, the 5850 series has looked a little out of sorts.
