I have experience with quite a few fans. I don't know the specifics regarding static pressure, but I know the specs for dB and for CFM.
I just bought a Xigmatek XSF-F1251 to get a bit more throughput in my case - and it works very well!! I hadn't heard of them before.
It puts out 78CFM. Sure feels like it. Claims to be <24db. Don't believe that. Sounds like more to me. It isn't loud at all, but it sounds more than that. I have no dB meter though!
Akasa Apache - these are amazing, pretty high CFM (68?) really quiet!!!
Arctic Cooling AF12025L claim 22dBA (and they are VERy quiet), but a meagre 26.7CFM. They were "holding up" the air in my case sadly. I replaced 2 of them with 1 Xigmatek and it has dropped a degree or 2. The noise has risen a bit, but I am not worried, I am now much happier with the air flow.
Scythe Kaze Juni 1900RPM - 110.3CFM. 37dBa. Yes to both. It is quite loud (though not annoying IMO.. you have this feeling that it is keeping things rightly cooled!). It really shifts air, and is really on the cheap side of fans. I VERY much recommend this fan if you need plenty of air and don't worry about the overall noise. Let's face it, the 220CFM fan I saw online is a bit louder
The others I have had first hand contact with are all stock, and are all unimpressive. Noisy for a poor CFM.
Hope this helps!
Mike
