You could bolt deep blue into the boot if you wanted, the resolution of the sensors such as a crank sensor havent really changed so it would make little difference.
All I'm saying is that I doubt ECU development had peaked ten years ago. I'm sure it's safe to assume that more emissive control on more modern engines is partly achieved through better resolution, faster processing and more complex control algorithms in the ECU.
Citing what is a more discrete sensor such as a crank sensor as some kind of proof is a bit of a reach, although I'd be intrigued to see what they actually are, even something as mundane as that I would be surprised if the resolution hadn't changed at all. But resolution of a sensors isn't everything, sample rates and complexity of control are all likely to increase on each generation of ECU.
You can see even through remapping how complexity is always improving, with more terms, more dynamic behaviour, and more control algorithms.
I may be wrong, but I really can't see any Euro IV ECU being less complex and having simpler control algorithms to a 1999 ECU from a normalish petrol engine.
But, if you have proof, I'm all ears, I don't have ECU specs of the two engines, but I'm sure someone as adamant as yourself clearly should be fully furnished with the relevant information to clear it up very quickly.
[edit]I've just asked an ex TRW employee that was there up until 2005, and he seems to think it's also more then likely based on stuff he was working on..
