- 16 Jan 2003
- Nottingham
It is a good read, but it confuses me why if you've read that you'd set a ridiculous 12GB page file size.
Just leave the page file alone, let Windows do it's own thing. We are talking about a game which was released 5 years ago, it probably wont make much of a dent on a modern systems RAM!
You said you've just reloaded your machie Vista Ultimate, what were you running before? Did you go to Vista because Civ4 wont run on 7 or because you are trying to save resources?
You havent actually explained why you dont want Windows accessing the hard drive?
If he is trying to save resources he should be running Windows 7![]()
It confuses me to why you wouldn't let Windows manage it in the first place.
I've tried but it's not simple. I do not want the hard disk to keep on whirling I guess the access to the swap file is the main cause of that.
Arg no don't disable the page file, loads of older applications need it to run.
Yet another myth I'm afraid.
No applications, not even the stereotypical Page File Hogger "Adobe Photoshop" has a line of code in them along the lines of: "if (pagefile = disabled) then start(random_error_message_timer)"
Disabling the page file is just about the worst thing you can do to your PC.
Could be Superfetch or Windows Search. Both of which will settle down after a week or two of use, if it's a fresh install of Windows.
The page file doesn't really cause frequent disk access unless you're close to the maximum of committed memory.
Yes, could you point me to some resources as to how to write batch command to close services? Thanks!I have 8gb Ram and I have my paging file set to min/max 3gb on my SSD. I have never seen any issues.
Vista is a resource hog, im surprised that you haven't moved over to Win7 which is far better.
Theres a lot of resources that are not needed if your just playing games. I'm surprised that no one here hasn't wrote a batch file to turn off many services when playing games. I have one for stopping IIS, and SQL servers when I'm not doing any development work.
