- 17 Dec 2004
- Crawley, WEST SUSSEX
Right basically my water pump went on my newly purchased Mk 4 2001 Golf So my dad came round and he fixed it all, but unfortunately I was at work while he did this and he put blue coolant in (G11 I believe) but the original colour coolant was pink (G12?) . So I now know that this is a big no no so will be doing a coolant flush but had a few questions:
I can't do the flush till Sunday, might be able to do tomorrow but not sure yet. So is it ok to drive it till Sunday? And also am I right in thinking all I need to do is to undo the drain valve under the car from the rad, put a hose in the expansion tank run the engine and wait till the water coming out is clear? Then fill with G12+ diluted 50/50?
Thanks for you help.
